Hummer H2 with Cummins 6bt power steering fluid question
Greetings everyone.
As the title states, I have a 2004 Hummer H2 with a cummins diesel conversion. I am in the process of replacing the power steering pump and would like to flush the system. I'm just not sure if I should use what GM or Cummins recommends as they can be different.
I want to use GM recommendations as it is "power steering fluid" as opposed to atf for cummins.
thanks
thanks
Thank you for your replies - I have atf from my tranny fluid change so i'll use that.
I picked the hummer up as a runner with many problems to solve. A Duramax diesel conversion seems more plug and play whereas the cummins is pure caveman!!!
oceanbrave
07-18-2017 07:03 AM
BlueH3
05-16-2015 08:05 PM
