Hummer H2 cold air intake/ filter options
Old Apr 14, 2015 | 02:16 PM
xtremez28's Avatar
Default Hummer H2 cold air intake/ filter options
I have a 2005 Hummer H2 SUT. I have been looking for a new air filter and wanted something more permanent than a paper filter. Found these two cold air intake on Amazon and wondered if anyone had any experience or opinion on these. Thanks!
2003 2004 2005 Hummer H2 6.0 6.0l Heatshield Cold Air Intake Kit Systems - - Amazon.com 2003 2004 2005 Hummer H2 6.0 6.0l Heatshield Cold Air Intake Kit Systems - - Amazon.com
Amazon.com: Hummer H2 6.0L V8 Silver Cold Air Intake Pipe+Heat Shield+Red Filter: Automotive Amazon.com: Hummer H2 6.0L V8 Silver Cold Air Intake Pipe+Heat Shield+Red Filter: Automotive
Old Apr 14, 2015 | 02:31 PM
LoJac963's Avatar
Typically the filters on those cheap kits are complete junk. You'd be better off spending some money on a better setup.
I have a Volant box paired with an AirDoc tube:
Old Apr 15, 2015 | 11:13 AM
xtremez28's Avatar
what about this as a direct replacement?
Robot Check Robot Check
Old Apr 15, 2015 | 11:15 AM
Indy's Avatar
As mentioned above, just get a direct replacement aftermarket filter (K&N or something similar). It's reusable, will give you better flow, but without the downsides of a cheap intake system.
Old Apr 15, 2015 | 12:32 PM
calif phil's Avatar
Lojac is right, those cheap Chinese knock off kits are junk. Follow his advise. Get a good one.
Old Apr 16, 2015 | 11:00 AM
Baldfox's Avatar
I put just the airdoc pipe in mine, yet to replace the filter, but more than happy with the pipe. See some of my other threads on here for sound clip and pics...
Old Apr 26, 2015 | 12:12 PM
Baldfox's Avatar
Just ordered an aFE 11-10088. Hoping that helps the old girl suck someone on Amazon already left a good review for an H2 on the site so fingers crossed!
Old Apr 28, 2015 | 10:34 PM
mattdillon's Avatar
I went with Ole' Faithful K&N! GL which ever you decide!
Attached Thumbnails Hummer H2 cold air intake/ filter options-20141110_164757.jpg
Old Apr 29, 2015 | 10:51 AM
xtremez28's Avatar
Let me know how the AFE filter works. I like K&N but don't have $400 to drop on one right now. Any issues with those sucking hot air from the engine bay?
Old May 2, 2015 | 01:03 PM
JMGPhila's Avatar
Why would anyone change the setup even a bit? The truck is built with cold air intake. The filters made by the various makers are high flow and perfect for the application. I use K&N on EVERYTHING ELSE I DRIVE OR HAVE DRIVEN, including oil, cabin and air filters. But, the H2 i take contains an air reservoir designed for the specific truck. Stick to the "paper" filters that only cost $40 every few year. I change it every year because they have gotten so cheap, but they can last a super long time.
