Hummer and Bikes ?
Old 06-27-2012, 08:27 PM
H2Miami's Avatar
Default Hummer and Bikes ?
Anyone knows a way to take mountain bikes on a Hummer H2 .
I have the rack but it doesnt fit with the spear tire , I cant use the one attached to the hitch cause I will be trailer my jetski ,
Any Idea ??
Old 06-28-2012, 06:41 AM
Det2008SUT's Avatar
Have you tried looking for a roof rack?
Old 06-28-2012, 01:40 PM
bapoptosis's Avatar
Default I've been looking too
Kinda screwed here. There is a tray for the factory crossbars, but I can't find one. Could get Thule rack system, but those get expensive.
Bikes are too big to fit in the cargo area unless "stuffed" in, spare tires carriers don't work because of license plate, and even if you had a hitch tray, you would need an extender to get around tire.
I did have a Thule roof system on my H3. Looked better than the factory bars. Putting bikes up there sucked since you had to stand on a tire to so it. Even had to lift up the tandem to get it up. Then you had to take them down...
I'm thinking I'll just put the tire in the cargo area and get a hitch mount.
Old 06-28-2012, 03:00 PM
Det2008SUT's Avatar
Ya I am in the same boat with a bike rack as well. I found out about the receiver extension so thats what I will end up doing.
Old 06-28-2012, 03:40 PM
Bunger's Avatar
This might work, with a bike hitch mount
Multi-Use Ball Mount
Old 06-29-2012, 09:35 AM
Egan's Avatar
Not the cheapest solution, but has multiple uses. I plan on doing something similar with the Gobi Ranger I have on order:
Old 06-29-2012, 05:18 PM
Pappibri's Avatar
Looking good... Nice set up you have there..
Old 06-29-2012, 05:19 PM
PaulB's Avatar
You know there's a 2" hitch receiver behind the front license plate bracket, right? Well, there is on my 2005 H2. I've mounted a two-bike carrier to the front and it works perfect. First thing I did was to buy and install a special license plate holder that is hinged on the bottom and it just swings down to expose the hitch receiver.
Old 06-29-2012, 09:07 PM
Egan's Avatar
Not mine, but I'll have a similar setup soon. I found this picture on the internet. Kudos go to whoever did it first.
Old 06-30-2012, 01:41 PM
H2CANEPADESIGN's Avatar
ditto what PaulB said. Put a hitch mount bike rack in the front receiver.
Quick Reply: Hummer and Bikes ?
