Headliner removal
Anything you see attached to the headliner has to be removed for it to come out, the biggest pain in the *** being the visors, I've never been able to get my visors out. In the H3 they easily just unbolt. For whatever reason in the H2 they're near impossible to get out without breaking them or damaging them or the headliner
- Marker light grommets
- Sun roof drain tubes
- Blower motor door under wiper cover
- Windshield seal
- Door seals sagging
- Rusted bolts in the roof rails
I wouldn't take the headliner down unless it's a last resort. Getting a new one would be extremely difficult if you damage it.
headliner
OK so the reason i need to drop it is the top corner lamps. 3 of the 4 don't work (not bulbs) and the electrical connection is broken to the sockets. There was a sunroof leak and debris that has caused some rotting in the wiring at various points so there's no current to those lamps.. WOULD LOVE to not have to drop it.
Sometime this summer I'm going to pull mine out as well since I need to have it recovered anyways. Plan is to do some needed work on my truck first so I'll have something decent to drive. Then I'll bring the H2 in for a LOT of projects. Headliner, remote start, running wiring for cameras, air tank and compressor (suspension plus ability to use air tools, horn, etc), electric fans conversion, dual battery install, probably new leather for the seats, fix sunroof (opens but have to assist it closed by hand), add a ton of felt tape behind all plastics (stop all the dang squeaks), along with probably a half dozen other projects.
I did it last week. Not bad at all. Took my time and it was not a big deal. Google on how to take out the sun visors as it is not self evident, rest was easy.
My leaks were coming from the front cab lights and I am in process of sealing them.
jolibee30
08-18-2010 05:35 PM
lucky19942001
01-24-2008 01:15 PM
mcne2026
01-09-2008 10:32 AM
