harder to turn left than right
Old 06-03-2019, 08:09 PM
flynripped's Avatar
Default harder to turn left than right
hi guys got another tech question. I brought my H2 in for a wheel alignment got a call saying that I need a power steering box pitman arm and inner tie rod. I have replaced everything and 2 months ago i replaced my power steering pump so now with a wheel alignment and a appointment for new tires tomorrow. Heres the ? now that everything is done its harder to turn to the left and when you turn to the right it feels good anyone have this happen
Old 06-04-2019, 07:28 AM
Honestly not sure myself. Maybe the steering stabilizer is binding up in some way?
Old 06-04-2019, 11:09 AM
madmayo's Avatar
Ive been battleing the same thing for a while now. I thought my mechanic had tightened up the adjustment on the steering box. This was after i had him do the pitman and idler arm and complained about the way it was handling after. This weekend it was really acting weird with some steering wheel shake. When i got home my front right wheel was smoking as the caliper was seized. I swapped it out with a new one and low and behold my steering feels way lighter. I was ready to teplace every component in my front steering and suspension. Probably not your issue. But worth looking into.
Old 06-04-2019, 11:27 AM
maxjeep's Avatar
Put it up on jack stands and cycle it side to side and see what it’s doing. You get underneath and have someone turn the whee, l you can probably do it by grabbing the tire and turn it back and forth.I had my gearbox rebuilt ( because I didn’t want a different box) I was able to turn my wheels from the tire really easily. I think you will get a better understanding of what is going on with it.
Old 06-04-2019, 12:52 PM
i remember reading that bilstein steering dampers also have that effect i think rancho as well because they work more like shocks then the OEM one that just dampens
chaos06
04-20-2018 06:53 AM
Sooner1
11-13-2016 07:26 AM
jsbihn
03-31-2015 04:43 PM
Oprime2014
10-03-2014 05:39 PM
eight_bit_micro
10-12-2008 08:53 PM
Quick Reply: harder to turn left than right
