H2 transfer case
I have a small leak from the very bottom of my transfer case. Can any one tell me how difficult it is to reseal the transfer case with RTV. The dealer told me there is no gasket, only RTV. What is involved to do this? Thanks for you r help and knowledge
May as well just go to your local lube shop and have em change the fluid in the t-case. they will have to reseal it when the reinstall the pan.
Seems like we have the same problem here. Anyone please share?
Originally Posted by H2CANEPADESIGN
(Post 285175)
No gaskets on the transfer case. Its a pain in the ass to get out as its heavy and awkward. I recently had mine serviced along with a new transmission and watched the whole process. You will need a good transmission jack or something similiar that's for sure and I don't thunk I'd try it at all laying on the ground. A fluid change might help if the existing oil is old and thin.
Tim |
Originally Posted by faella
(Post 371944)
Hey everyone, i have a 2006 H3 3.5L and I get this reasonably loud howling sound when I am pressing on the gas pedal. It sounds like it overlays the normal engine sound. It begins around 35mph, i have only taken it up to around 55mph and the sound is still present. If i let off the gas pedal, the howling sound stops completely. It will resume as soon as I press the gas pedal again. My tire tread is semi aggressive but >75% tread life.
snaptube vidmate |
Only use gear oil in the transfer case. . Dex trans fluid recommended by dealer only grinds your tcase to powder with no viscosity. Did my buddys H2. Transfer case is filled with gears. 260K on my tcase changing the gear oil in all three sumps every30K and still going strong.
Transfer case vs transmission
Are we perhaps confusing transfer case fluid with transmission fluid? I want to change transfer case. Videos I’ve seen just show a drain plug and fill plug to remove.
Originally Posted by tharber
(Post 371955)
Tim |
