H2 SUT /2007 Climate control failure
Hello,
I have a problem with the air conditioning i can t activate it when i press the AC button and outside are below 5 degrees Celsius, it can be seen in the movie. Now the weather is warmer but it works intermittently, i press the AC button and the snowflake pictogram remains active ,i receive cool air inside but I raised the hood and noticed that the compressor clutch engages and disengages the range about 3-4 seconds.
Newer even if air conditioning is now closed but the ventilation is on ,the compressor clutch engages and disengages from 3-4 seconds.
I checked if the air conditioner is sealed and i change the cooling agent with new one in a workshop.
Do you have any idea what I could check?
Thank You.
https://www.youtube.com/watch?v=oua9...ature=youtu.be
Thank You.
njhusker
11-04-2019 11:36 AM
drgray7
05-19-2010 10:55 PM
matelblapav1
02-01-2009 06:37 AM
HammerDown
08-30-2007 04:54 PM
crc2k
07-14-2006 11:54 PM
