H2 need help
Old 09-23-2012, 08:47 PM
googie714's Avatar
Default H2 need help
OK need some help, center marker lights front and rear do not work also mirrors work but will not fold in, air compressor not working
2003 H2
thanks
Old 09-23-2012, 10:03 PM
KA H2's Avatar
Check your fuses and relays first.
Old 09-24-2012, 10:20 AM
googie714's Avatar
fuses and relays all good did that first
thanks
Old 09-24-2012, 04:40 PM
Pauldy's Avatar
If you search the forums there are all kinds of issues with the mirrors so knowing what your particularly experiencing is hard to tell. It can be anything from just the motors locking up to the point of requiring total replacements to something as a simple as a loose wire harness.
Do you have pictures of your mirrors?
Old 09-24-2012, 04:43 PM
Pauldy's Avatar
Also for the marker lights, have you tried replacing them? I have an 03 and replaced all mine a few months ago.
Old 09-24-2012, 04:50 PM
Pdmiller's Avatar
my compressor does not work neither do the mirrors-- time to search
Old 09-24-2012, 08:55 PM
googie714's Avatar
Old 10-07-2012, 09:55 PM
googie714's Avatar
all bulbs bad thank you!!!! i,am a dummy
Old 10-08-2012, 10:36 AM
Pauldy's Avatar
NP might want to check gaskets too since you just changed them to make sure there is a good seal still or you might end up with water coming in next.
Old 10-08-2012, 04:54 PM
googie714's Avatar
ok if seals are bad how do you know, where can I get new ones also lost one of the clips that holds the light down where can I get one need help
Quick Reply: H2 need help
