H2 hummer radiator
has anyone upgraded to an all aluminum radiator.. I found one that says it will fit .. but the diementions are a lil off ... what have you used ? what brand ? ... how was fitment ? would I be ok with this...? 205180 Muscle Car 00 07 Chevy GM Silverado Sierra Radiator Northern | eBay
Originally Posted by ON IT
(Post 333967)
And Be Cool does as well. Neither one is going to be cheap, but both are well made and will last a long long time. |
This is what I had planned
Be cool 60102 @ $750 Not cheap but in the long run it is worth it |
A radiator is one place you don't want to skimp. I also want a BeCool radiator.
Sorry to bring up an old thread but I will be replacing my radiator soon.
I know I want a beCool radiator but I wasn't sure which one. I've seen 67102, 62102, and 60102 referenced. So I called becool and it sounds like the only difference is how many coolers it comes with, if at all. So 67102 comes with oil and tranny cooler, 62102 comes with just a tranny cooler, and 60102 has no coolers. And they are priced accordingly. I have already bypassed the tranny cooler in the stock radiator and added a larger tranny cooler. That solved the tranny heat issue while towing. So I think I want the 60102. But I never looked to see if we have oil lines running through the stock radiator. |
Originally Posted by mulepic
(Post 341426)
I know I want a beCool radiator but I wasn't sure which one. I've seen 67102, 62102, and 60102 referenced. So I called becool and it sounds like the only difference is how many coolers it comes with, if at all. So 67102 comes with oil and tranny cooler, 62102 comes with just a tranny cooler, and 60102 has no coolers. And they are priced accordingly. I have already bypassed the tranny cooler in the stock radiator and added a larger tranny cooler. That solved the tranny heat issue while towing. So I think I want the 60102. But I never looked to see if we have oil lines running through the stock radiator. I just checked, it looks like we have oil lines running through the driver's side of the radiator. So that means 67102 would be the correct becool radiator. Or I believe you can save a few bucks and get 66102 which is the same thing but not polished. |
Just ordered the 66102 direct from Be Cool b/c they needed to provide an adapter for our oil lines that run through the radiator. I'll post some pictures of the install.
Looking forward to cool running while towing up those hills in the 110 heat out here. |
Ron Davis Radiator
(Post 333967)
Due to my engine modifications I cannot go back to stock. After considerable positive discussions, C&R Racing is building a custom R-Fin radiator for it now, due back to me at the end of December 2021. Will post performance results after installation. |
