H2 cruise control not even turning on
Old Oct 19, 2011 | 11:20 AM
mrvictory1999's Avatar
Default H2 cruise control not even turning on
I recently purchased a 2007 H2 and have noticed that the cruise control won't even turn on. When I flip the switch on the turn signal, I get no response or light on the dash or anything else. And hitting the button to set the speed does nothing.
I tested the fuse labeled "CRUISE" on the left side of the dash and it is good. I also put in a new fuse just for good measure but still saw no response from the cruise control system.
I've searched the forums and it doesn't seem like a common problem. Any thoughts on what else to try before I bite the bullet and take it to the shop? Are there any other fuses related to the cruise control that I should check?
Old Oct 28, 2011 | 02:57 PM
I fixed it. Turns out, the fuse labeled "BRAKE" which is right next to "CRUISE" was burned out. Replacing it fixed the problem.
So for future reference, there are TWO fuses in the interior fuse box that could lead to the cruise control not working.
Old Dec 19, 2011 | 12:29 AM
KTM640Dakar's Avatar
A burnt out tail light/rear running light will cause your cruise control to not work also.
Old Nov 21, 2020 | 12:14 PM
raftrman's Avatar
Default cruise control fixed
On the upper brake pedal there is a black electrical box, and a wiring harness that plugs into that black box, i wiggled the harness that plugs in to the black box, and my cruise control started working again. Kind of hard to get in there, take a flashlight. I checked my fuse, and brake lights first. They were ok. I have a nice 05 H2 with 56k on it. I love that thing. Good luck.
TacoDeMaiz
Mar 14, 2020 08:24 PM
joenuzz
Dec 29, 2016 07:05 PM
CudaJimmy
17
Dec 18, 2015 03:40 AM
SCVipermad
Aug 11, 2010 08:35 PM
E T H
Aug 8, 2010 07:50 AM
