H2 Air Suspension
H2 Air Suspension
My rear end keeps settling down, when I start up it slowly comes back up. If I always leave it in the 2" raised position it doesn't go down as often. Is there some fix to th compressor that could stop this?
Time to get some soapy water and spray your air bags and look for leaks. Most likely your air bags are shot. Not that expensive or hard to replace. You need to fix it before you burn up your air compressor.
calif phil
02-25-2011 01:00 PM
