Mine was a bad BCM, if you go with a used one, make sure you match the VIN, and I would only pay $150 for it. If you want to go with new like I did,,, replace it,, go through the security bypass programming and then take it to a dealer to finish programming. I will add two links, one for the part, for $170 new OEM and the other for the security video.
2003 HUMMER H2 Parts - GM Parts Direct Hope this helps |
Did you find out the unknown driver issue with windows not working and all the other
Originally Posted by Dule-p
(Post 261780)
Hello everybody!!!
Before few days, my h2 stoped working. On display is "Unknown driver", and it can not start engine, actually it start on a second and then turn off, (like immobilizer). Central locking, el.windows, gauges, radio....does not working too!! Unfortunately, i have only one key without remote. I searched forum and i find similar post, but I didn't find right answer. Can someone help me??? Thanks in advance!! |
Did you read the thread David? He replied what the problem as have others with the same problem.
