H2 03, trany
Old 08-13-2018, 07:25 PM
JB357OOOO's Avatar
Default H2 03, trany
Will running my Hummer h2 at idle with no transmission fluid damage my trany?
Old 08-14-2018, 08:53 AM
Why?????? What would be the purpose of doing it?
Old 08-15-2018, 07:57 AM
calif phil's Avatar
Need more info! Did you drop the pan and forget to refill it? Brand new trans that is bone dry? Fluid not showing on the dipstick? What's the story?
Old 08-15-2018, 09:34 AM
JB357OOOO's Avatar
The trany line to the radiator came off while driving, the truck stopped moving, but I had the truck running for an hour waiting for AAA for AC and music After being towed to the nearest gas station I added 7 quarts of fluid to fill to proper level. The truck was moving fine an after but 30 min later trany started slipping, I haven't started it since. Also, I used standard automatic fluid, NOT VI when adding the 7 quarts. I'm trying to figure if I drop the pan and pump all fluid out the converter, change all the fluid will I be good.
Old 08-16-2018, 07:45 AM
calif phil's Avatar
I am in shock that you would run the truck for an hour with the tranny line off. I would say, don't waste your money on more fluid and start shopping for a trans rebuild. That hour with the AC running just cost you. $2500.
Old 08-16-2018, 11:59 AM
JB357OOOO's Avatar
But the truck wasn't being driven, it was in park
Old 08-16-2018, 05:31 PM
Was an hour of "AC and music" worth $3000+?
Do you think that no part of the transmission and torque converter move when in park?
Old 08-16-2018, 06:10 PM
JB357OOOO's Avatar
Well thinking about it logically the transmission's job is to switch gear so if the truck is not moving the gear will not switch. But I did not think about the converters attached to the flywheel which will spin when the engine is running. SMDH
Well looks like I screwed up, Well on the bright side I'm having the trany rebuilt 4 only $ 1,300. that's right only $ 1,300 at Remco, I used my tax ID from my construction company and told them I'm a repair shop subbing them the trany job so they assume I will send them more trany work.
Old 08-16-2018, 06:14 PM
JB357OOOO's Avatar
See so I'm far from an idiot which I'm sure some of you thought Home Renovations, General Contactors | Brooklyn & Queens NY
Old 08-17-2018, 09:12 AM
calif phil's Avatar
So your saying on a public forum that you are , Cheating the state by using your tax ID # and you are lying to the trans shop to get a better deal.
I guess New Yorkers do things different than we do in KS.
Joe Canter
08-27-2019 12:57 PM
cjd9153
06-05-2019 10:55 AM
zzpw3x
41
06-10-2015 08:00 PM
ashinc
05-14-2012 02:42 PM
uzz32soarer
10-30-2009 08:15 AM
Quick Reply: H2 03, trany
