fuel tank
I had a purge valve go bad in My 09 H2 top of the tank. Took it to the dealer under Warranty. The Mechanic had been working on H2's ever since they came out. Rather then drop the Tank to fix it....this is what he came up with. He went out and bought a vertical Mirror for a Closet Door. Then he glued some magnets to each corner and a few in the center.
Next step was to stick the Mirror to the bottom of the H2's Floor above the Tank. This way he could see in reverse and remove the purge valve while the H2 was on the lift.He had also stuck a Light up there to see. The Money book gave him 2 plus hours to do the job. He did in 20 min and got paid for 2 hours work on commision. Smart MF.
Also said it took a while to learn how to crank the hand tools in reverse of what he was looking at......L.O.L.
So, a visit to a shop I use on occasion, yielded a used tank out of state for $650, now on its way here. Calls to several radiator shops about re-welding the seam was no good. I may experiment on my old tank and see what I can do. Thanks to all for suggestions and info.
Rhett
Rhett
Here's a Good Old Boy With The answer
I can see in the near future as sources for used tanks will dry up, it will probably be necessary to fabricate brackets for an aftermarket aluminum fuel cell. They are available in all sorts of dimensions and volumes. At the current prices for an old used plastic tank.... Perhaps we are already on the verge of having to fabricate a different option....
If you're fabricating brackets, it may be cheaper and/or easier to fabricate a bracket to adapt a different GM fuel tank if it fits (like Suburban, 2500, etc.)
