front coil over conversion
Has anyone done a coil over conversion on the front suspension? I just hate having my T-bar hang down so low below my frame. (I have a 6" fabtec)
I've seen some kits on the gm 2500's but non specifically for the h2. am I kind of **** out of luck and need to fab one up myself from scratch? Thanks for your replies. |
How much money do you want to spend?
I replaced my UCAs w/ boxed ones for a 2500. I believe that everything with the IFS on the H2 is interchangeable w/ similar year Chevy/GMC 2500s. Here's an example of this being done: New Chevy/GMC HD 2-3'' Coilover Conversion System If you have the money, King will build whatever you want. Not sure about Fox. |
I got money but can’t justify spending 10000 on a kit that really is only uppers and lowers with extended cv’s and new coil overs. I’m going to make a mid travel / long travel kit myself for the h2 that bolts on to factory mounting brackets. Probably take me a month or so to get all angles and geometry perfect but when I do I will post a build thread and probably sell a few copies if I feel up to it. Plan on tog welding whole thing with extra thick steel. Even though it will be heavy it should be almost indestructible |
Tig**** |
