ebcm cross reference
Old Aug 25, 2014 | 12:26 AM
dino631's Avatar
Default ebcm cross reference
Hello .. wanted to say this forum is great been reading lots info for the last couple weeks .. I just purchase a 03 .. I've been reading about problems with the ebcm . As many here the brake, traction and abs light is on had the truck scanned and code was I believe co550 it said cannot communicate with ebcm . I searched and found out u can fix it yourself so I tried and just made a mess of it . Long story short I should just get one I looked online can't find one . Unless is new . Ive been saving for 3 years to buy this truck and I love it . Runs great no problems beside the ebcm . Not communicating . I looked online and if I'm correct it has a Bosch 5.3 I went to junkyard and looked at the Chevy 3/4 but it looked different . I also found online that some VW have them found one looks same but the plug was different. I live in Florida and here u need abs people like to slam brakes here and with no abs on my h2 forget it I may hurt someone . I found a ac Delco part number 19121234 price is 450.00 ( plus I would have to take to dealer and get it programmed to truck am I right .) I'm hoping someone can help me save money and a headache. I should just sent mine out to get repaired lesson learned many thanks
Old Aug 26, 2014 | 06:28 PM
ant69's Avatar
I got my ABS to start talking again simply by pulling out the 10 amp fuses under the hood for few seconds. They were the "IGN E fuse and IPC/DIC fuse" In that order first one checked cleaned and replaced and then the other. When I started it my lights flashed reset and the Check ABS message went away its been working fine for a few days, but all is well. I had been staring at that Brake monitor message since June and was trying to figure out if I was going to replace the ecbm myself or have it done. Then the other day while out driving my gauges just quit working. I figured fuses it worked... only it fixed more than expected! Hope it helps
Old Aug 27, 2014 | 08:08 PM
dino631's Avatar
Default thanks for reply
I did check fuses and all good . At this point in time I need a new one. Mine is in garbage I just can't believe its so expensive . The cheapest I found is 375. I was wondering if that same ebcm came in a different truck. I could just drive without abs but people here in Florida like to slam on brake and get smashed in the rear . They don't do it on purpose but its a common accident here . Ive been online and no luck. Besides the one I found for 375. I may have to just get it. But hopefully someone here may shed light on another vehicle that may have the same item thanks again for reply
dino631
Aug 25, 2014 12:09 AM
Sgill
19
Apr 25, 2013 05:38 AM
loblouie
16
Apr 21, 2007 05:57 PM
Larain60
Feb 10, 2007 09:19 PM
HummerGuy
Aug 10, 2006 03:24 PM
