Drivers side carpet wet
For the past month or so when it rains very hard I have noticed the drivers side carpet gets soaked under the floor mat.Anyone else ever have this happen to there H2.What should I look for to fix this.Thanks...
I had a similar problem recently. It was the seal around the roof marker light above the drivers seat. It had perished and water was seeping into the light cluster and then travelling into the inner roof skin, down the windscreen pillar and onto the carpet. You'll be able to confirm this my removing the windscreen pillar so you can see the bare metal and checking for dampness. Or similarly checkinh above the roof lining.
I fixed mine by using a silicone gel and covering the inside of the light cluster in it to form a waterproof seal.
DJONES
01-22-2013 04:13 PM
Diablito
04-24-2010 05:59 PM
