dragging noise on more than 20 Hummers
Old 12-01-2012, 03:36 AM
Ahmad's Avatar
Originally Posted by Ahmad
The driveshaft moves side to side
What is the problem??
Is it Serious ????
Im talking about the front drive shaft
Old 12-01-2012, 09:49 AM
Man1nboat's Avatar
Sounds like your differential is shot... Does it have fluid?
Old 12-01-2012, 09:57 AM
Ahmad's Avatar
yes it does
Old 12-02-2012, 07:18 AM
dr.drew2's Avatar
you need to look at the differential fluid, you are looking for metal particles in the fluid. If this is there you likely have a bearing in your front differential that has gone bad
Old 12-02-2012, 12:51 PM
Ahmad's Avatar
I Found that if I turn right or left the sound is getting low
Old 12-02-2012, 06:59 PM
dr.drew2's Avatar
Default check your front hubs
check your front hub assembly. they are notorious for failure
Old 12-07-2012, 09:20 AM
Man1nboat's Avatar
Did you find out the problem??
Old 12-08-2012, 01:33 PM
Ahmad's Avatar
Yes I did .
My problem were the tires ( Hankook 315/70/17 ) made in 2010
Old 12-08-2012, 03:52 PM
nlhummer's Avatar
What do tires have to do with that?
Old 12-09-2012, 12:24 AM
Man1nboat's Avatar
Really? I have Hankook tires on my Jeep and love them... The ones for the H2 are D rated. Doesn't make sense...
Quick Reply: dragging noise on more than 20 Hummers
