dragging noise on more than 20 Hummers
Old 11-30-2012, 11:02 AM
Ahmad's Avatar
Unhappy dragging noise on more than 20 Hummers
Hi friends.
My name is Ahmad & I am the leader of hummer arabia team.
a lot of my members have a problem we can't find a Solution for it. the problem on Hummer H2 only .
It is like dragging noise under the driver seat near the front differential
when acceleration from 20 to 40 miles.
The same dragging noise on more than 20 Hummers but some of them the sound is annoying & some of them brely hear
In my hummer I changed the both sides wheel hup in the front & nothing changed.
When I lift the car the sound disappears.
The differential oil is good. Can any one tell us what is the problem??
Old 11-30-2012, 12:13 PM
atvspeed4's Avatar
It might have something to do with your brakes. I had that issue and it was the dust shield touching the rotor. Also after wheeling ive had mud and small rocks cause issues with the rear brakes.
Old 11-30-2012, 12:46 PM
Ahmad's Avatar
thank you for your response
I did clean it & the sound still the same
Old 11-30-2012, 12:51 PM
Can you post a video with the noise in it.
Old 11-30-2012, 12:52 PM
Ahmad's Avatar
I forgot to tell you that after 60m/h the dragging noise Becomes whining noise
Old 11-30-2012, 12:57 PM
Ahmad's Avatar
It won't be heard on a video or sound clips. You have to drive it to feel it & hear it
Old 11-30-2012, 02:05 PM
nlhummer's Avatar
Can you pay for a couple of plane tickets so we can come and check it out?
I do not have the issue you are describing by the way
Old 11-30-2012, 02:10 PM
Man1nboat's Avatar
"Could" it be the differential?
Old 11-30-2012, 03:19 PM
dr.drew2's Avatar
answer yes check for leaks grab driveshaft and see if moves side to side
Old 12-01-2012, 03:13 AM
Ahmad's Avatar
The driveshaft moves side to side
What is the problem??
Is it Serious ????
Quick Reply: dragging noise on more than 20 Hummers
