Display gauges without function H2
My H2 SUT display gauges speedometer and odometer stopped to fonction. Display light and directions sign and engin checklight still works. What should I do. Because I m in Senegal and here is no GM representative.
Check ALL your fuses ( and I do mean ALL ), GM in their infinite wisdom did not list all the connections to all the fuses. If no joy, then personally I'd just pull it and send it in there are a few small companies that do gauges and they will go through and replace what needs to be. Also a lot will swap out the lights for leds ( colored or white ) usually for a bit over 100$.
BTW you can still use the truck without the cluster in...
jeremiahpreston
01-10-2009 08:22 PM
jrs2005
04-21-2008 09:52 AM
Nxsov180db
04-17-2008 04:51 AM
littlehummerboy
05-10-2007 08:58 PM
