Clearance lights
Small clip underneath.... See the pic. Simply push it left or right toward the spring side to unhook the opposite side. If you push one way and it will not move then try the other direction. You can also use a pick or tiny thin screwdriver and press against and release the spring clip side as well to remove them but this does have more chance of damaging the gaskets.
Also I'd strongly suggest getting new gaskets versus putting any sort of silicone around them. You need to be able to remove them to replace the bulb and silicone is near impossible to remove and nothing really seals well or sticks to dry silicone (not even more silicone) which can cause further leak issues later.
Seller on Amazon has a full set of the gaskets for a decent price and can also find them on eBay.
Link to gaskets.....
Most likely. Only issue I could see happening is that the LED is larger and won't fit in the plastic light shell. I'd buy one and try it before buying them all.
I put LEDs in mine. So far, so good. They are a lot more intense & you can see the bulbs instead of just the actual housing. I think incandescent looks better, but I won't argue with the results.
You can buy LED bulks on ebay fairly cheaply, so it's not a bad option to try.
Beast05
09-09-2016 01:32 PM
ONALLFOURS
38
06-30-2008 02:39 AM
