A/C Leak - Any common issues?
2005 H2 A/C refrigerant was very low and not getting very cool after refill. Oh yes I have heard some squeaking and squealing which has caught my attention in the past.
Before getting into this too deep can anyone suggest places to start looking. Here in UK its probably going to be a DIY fix or at least getting in the necessary parts.
A quick look on the furums suggests the A/C compressor and or the drier, I see there is a kit on ebay. Does anyone have any experience on A/C or replacing the compressor, is it a DIY job?
Any suggestions welcome!
I find the compressor to be the most common source of leaking but overall GM builds a pretty good system. The compressor, accumulator, Orfice tube , oil and R134A should be all you need, if the compressor is your leak. UV Dye is the easiest way to find a leak
If you have a leak then look for an oil spot on the lines and all components of the system. The oil travels with the refrigerant so if the refrigerant is leaking then there will be an oil spot at the leak. If I cannot spot the oil spot then I use a soap mixture and spray on the system and let sit for a few minutes and then look for a patch of small bubbles (the system needs to have some pressure on it). I will usually pick up a bottle of bubbles from one of the local stores, the kind that you buy for the kids to blow bubbles with.
I would start by checking the service taps on the high and low side lines, there are plastic caps screwed on them and will leak over time.
I would find the leak and try and repair it before changing the compressor or anything else.
Worst case scenario will be the evap coil is leaking, its under the dash and can be rather hard to change out.
Neal
Neal
If the leak has been repaired and its not getting as cold as it was prior to the repair and re-charge the servicing may not have been done correctly.
Did your mechanic use service gauges to fill the system and if so do you know what pressures the system was at after filing with the system turned on and what were the conditions while servicing, air temp., idling or above idle was the system on high with the fan on high?
Neal
Neal
I would say everything... I have been fighting with my AC for years now. Every year or two it has some kind of issue
This year it did it again. Leaking at the condenser. Before it was the compressor and condenser.
Tharber, couldnt you just replace the shreader valve? or is it some other valve i am unaware of?
not to hijack, but has anyone left a AC temp probe in their air vents to measure the temps, and if so could tell me what the constant temp is on 3 bars of fan, and the air rec-circ?
