Buying this wheels .. need advise
Im looking to buy these wheels http://www.amazon.com/gp/aw/d/B004UR...I1GTDKGMWGM9IO
Please could you advise if the offset 1" is going to looks good
I don't plan to use any spacers or change wheel size
any advise appreciate. I'm a totally ignorant when talking about wheels
Don't these require the special lugs?
I have a set of these in 18" (different offset than what you need, I think) & normal lugs won't fit & are you too shallow. As well, you can't fit a normal socket in, so they are provided.
Mine were similar to these, but obviously a different depth to accommodate the offset.
I think I got my rims from 4wheelparts. I believe they can at least help you with the offset & lugs you need. Obviously buy from whoever is the cheapest, but at least you can get some reliable info that way.
Amazon.com: DPAccessories D5148P-2305/24 24 Premium Black Duplex 6 Spline Drive/Tuner Wheel/Lug Nuts (14x1.5) 2.02" Tall: Automotive
Thanks for the advise and the link ... Already put the Wheel/Lug Nuts on my wish list ... Is there any disadvantage in replacing the Oem Lug nuts
Do you know if the 1 offset is pushing the wheel far from the hub or opposite
While searching I was learning some imp things . I just realized the Offset is the most or only important part of the wheel measures ....
NOw my next question is .. What is the OEM Wheels offset for the H2 ... I found many different answers but noone seems to agree
Aftermarket lugs will hold as long as they are installed correctly. The reason you can't use them with the fuel wheels is due to the offset, at least in my case. Only a special thin wall socket would work. Luckily, it comes w/ the lug set.
The benefit of this is that unless someone is walking around w/ that socket, they cannot steal your wheels & tires.
In general though, you're right in terms of actually making sure you don't have any tire rub issues.
The duramax forum & diesel place (along with others) both claim this:
Hummer H2 Wheels:
Size: 17" x 8.5"
Bolt Pattern: 8x6.5
Off-set: 18 MM
Backspacing: 5.5"
Size: 17" x 8.5"
Bolt Pattern: 8x6.5
Off-set: 18 MM
Backspacing: 5.5"
Link 1 Link 2 Link 3
Here's some more info on wheels in general: Link
What data are you getting?
My Method wheels are the same, lug holes are very tight. Tirerack included special lugs and a thin wall socket. Even with the thin wall socket it chewed up the pain on the inside of the lug holes.
I bought another set of splined lugs off ebay because they are considerally thinner due to their design. With the special socket they require it doesn't come close to touching the lug hole walls. This is the second set of splined lugs I've used and never had an issue.
They come in chrome and chrome black:
32 Chrome Spline Lug Nuts 2 Keys 14x1 5 8x6 5 Chevy GMC Silverado Hummer | eBay
cgray11
24
09-19-2014 06:54 AM
4u33er
05-09-2012 05:52 AM
djezrock
11-18-2011 05:51 AM
shawnnlivier
02-23-2007 06:33 AM
andyhks
04-23-2006 01:11 PM
