Amazon parts
Why dont we start a thread fir Parts that fit H2 from Amazon
Would.be easy to look and find the part with the confidence that it fit I bought a lot from Amazon . Will start posting a few confirmed fit to H2 or Mods Hopefully not going against any forum rules |
Brake pads front and rear
ACDelco 17D785CH Professional Ceramic Front Disc Brake Pad Set ACDelco 17D784CH Professional Ceramic Front Disc Brake Pad Set Fuel Injection Throttle Body with Throttle Actuator ACDelco 12679525 GM Original Equipment Fuel Injection Throttle Body with Throttle Actuator 8 New NGK Iridium IX Spark Plugs TR5IX # 7397 8 New NGK Iridium IX Spark Plugs TR5IX # 7397 ACDelco 9748HH Professional Spark Plug Wire Set ACDelco 9748HH Professional Spark Plug Wire Set ACDelco A3100C Professional Air Filter ACDelco A3100C Professional Air Filter |
ACDelco 17D785CH Professional Ceramic Front Disc Brake Pad Set ACDelco 17D785CH Professional Ceramic Front Disc Brake Pad Set Fuel Injection Throttle Body with Throttle Actuator ACDelco 12679525 GM Original Equipment Fuel Injection Throttle Body with Throttle Actuator 8 New NGK Iridium IX Spark Plugs TR5IX # 7397 8 New NGK Iridium IX Spark Plugs TR5IX # 7397 ACDelco 9748HH Professional Spark Plug Wire Set ACDelco 9748HH Professional Spark Plug Wire Set ACDelco A3100C Professional Air Filter ACDelco A3100C Professional Air Filter |
Adaptor for LED lights
Fontic 9007 Male to H4 Female Adapter for Hummer H2 Headlight (Adapter) Led . NEEDS MODIFICATION DOT Approved 7'' Black Daymaker LED Headlights + 4 ''Cree LED Fog Lights for Jeep Wrangler 97-2017 JK TJ LJ LED bulb for reverse or Drl JDM ASTAR 1200 Lumens Extremely Bright 144-EX Chipsets 3056 3156 3057 3157 LED Bulbs with Projector for Backup Reverse Lights, Xenon White ACDelco 213-4514 Professional Engine Coolant Temperature Sensor ACDelco 22463M Professional Lower Molded Coolant Hose ACDelco 26390X Professional Upper Molded Coolant Hose Kicker CST20 3/4" Tweeter-Each (Black) ACDelco 36299 Professional Idler Pulley with Bolt, 17 mm Insert, Dust Shield, Retainer, and Spacer ACDelco 38158 Professional Automatic Belt Tensioner and Pulley Assembly |
THANKS Saving the List...
ACDelco 213-1161 GM Original Equipment Heated Oxygen Sensor
ACDelco D1846A GM Original Equipment Engine Oil Pressure Sensor ACDelco 15-50156 GM Original Equipment Air Conditioning Clutch Cycling Switch ACDelco 251-743 GM Original Equipment Water Pump with Gasket ACDelco 15-11057 GM Original Equipment Engine Coolant Thermostat Water Inlet Assembly Console Vault Hummer H2 2001-2007 & H2 SUT 2002-2007 - 1001 - Massive 12 Gauge Cold Rolled Plate Steel, Welded Tab And Notch Seams - Superior 3 Point BlueFire Waterproof Dual 2 USB Outlet 1A & 2.1A Port Socket Charger Power Adapter For Car Boat Motorcycle 12 volt Outlet LED EBC Brakes GD7210 3GD Series Dimpled and Slotted Sport Rotor ACDelco 24208576 Professional Automatic Transmission Fluid Filter Kit Bilstein 33-174525 46mm Monotube Steering Damper Bilstein 24-186735 Front Shock for GM K2500 and 3500 Bilstein 24-185912 46mm Monotube Shock Absorber |
great idea, I just paid $80 for a oil pressure sender at the dealer
I prefer to us ACDelco/OEM parts when replacing, Thanks for putting this together Neal |
subbed in
Gm "Green" Keys General Motors, ARM, 15592573
Dynatech Headers 2008/09 LED Headlamp Conversion Truck-Lite 27270C 7" Round Truck-Lite 98630 LED Headlamp Anti-Flicker Module Harness - PWM Pule Width Modulation Adapter aFe Air filter (dry) aFe Air filter (oiled) |
Nice. Thanks
| All times are GMT -5. The time now is 02:18 AM. |
