Amazon parts
Old 03-14-2018, 10:09 PM
H2Miami's Avatar
Default Amazon parts
Why dont we start a thread fir Parts that fit H2 from Amazon
Would.be easy to look and find the part with the confidence that it fit
I bought a lot from Amazon . Will start posting a few
confirmed fit to H2 or Mods
Hopefully not going against any forum rules
Old 03-14-2018, 10:14 PM
H2Miami's Avatar
Brake pads front and rear
ACDelco 17D785CH Professional Ceramic Front Disc Brake Pad Set
Amazon Amazon
ACDelco 17D784CH Professional Ceramic Front Disc Brake Pad Set
Amazon Amazon
Fuel Injection Throttle Body with Throttle Actuator
ACDelco 12679525 GM Original Equipment Fuel Injection Throttle Body with Throttle Actuator
Amazon Amazon
8 New NGK Iridium IX Spark Plugs TR5IX # 7397
Amazon Amazon
ACDelco 9748HH Professional Spark Plug Wire Set
Amazon Amazon
ACDelco A3100C Professional Air Filter
Amazon Amazon
Old 03-14-2018, 10:15 PM
H2Miami's Avatar
Amazon Amazon
Amazon Amazon
Amazon Amazon
Amazon Amazon
Amazon Amazon
Amazon Amazon
Old 03-14-2018, 10:26 PM
H2Miami's Avatar
Adaptor for LED lights
Fontic 9007 Male to H4 Female Adapter for Hummer H2 Headlight (Adapter)
Amazon Amazon
Led . NEEDS MODIFICATION
DOT Approved 7'' Black Daymaker LED Headlights + 4 ''Cree LED Fog Lights for Jeep Wrangler 97-2017 JK TJ LJ
Amazon Amazon
LED bulb for reverse or Drl
JDM ASTAR 1200 Lumens Extremely Bright 144-EX Chipsets 3056 3156 3057 3157 LED Bulbs with Projector for Backup Reverse Lights, Xenon White
Amazon Amazon
ACDelco 213-4514 Professional Engine Coolant Temperature Sensor
Amazon Amazon
ACDelco 22463M Professional Lower Molded Coolant Hose
Amazon Amazon
ACDelco 26390X Professional Upper Molded Coolant Hose
Amazon Amazon
Kicker CST20 3/4" Tweeter-Each (Black)
Amazon Amazon
ACDelco 36299 Professional Idler Pulley with Bolt, 17 mm Insert, Dust Shield, Retainer, and Spacer
Amazon Amazon
ACDelco 38158 Professional Automatic Belt Tensioner and Pulley Assembly
Amazon Amazon
Old 03-15-2018, 03:18 PM
TeeStu's Avatar
THANKS Saving the List...
Old 03-15-2018, 06:01 PM
H2Miami's Avatar
ACDelco 213-1161 GM Original Equipment Heated Oxygen Sensor
Amazon Amazon
ACDelco D1846A GM Original Equipment Engine Oil Pressure Sensor
Amazon Amazon
ACDelco 15-50156 GM Original Equipment Air Conditioning Clutch Cycling Switch
Amazon Amazon
ACDelco 251-743 GM Original Equipment Water Pump with Gasket
Amazon Amazon
ACDelco 15-11057 GM Original Equipment Engine Coolant Thermostat Water Inlet Assembly
Amazon Amazon
Console Vault Hummer H2 2001-2007 & H2 SUT 2002-2007 - 1001 - Massive 12 Gauge Cold Rolled Plate Steel, Welded Tab And Notch Seams - Superior 3 Point
Amazon Amazon
BlueFire Waterproof Dual 2 USB Outlet 1A & 2.1A Port Socket Charger Power Adapter For Car Boat Motorcycle 12 volt Outlet LED
Amazon Amazon
EBC Brakes GD7210 3GD Series Dimpled and Slotted Sport Rotor
Amazon Amazon
ACDelco 24208576 Professional Automatic Transmission Fluid Filter Kit
Amazon Amazon
Bilstein 33-174525 46mm Monotube Steering Damper
Amazon Amazon
Bilstein 24-186735 Front Shock for GM K2500 and 3500
Amazon Amazon
Bilstein 24-185912 46mm Monotube Shock Absorber
Amazon Amazon
Old 03-16-2018, 11:46 AM
legerwn's Avatar
great idea, I just paid $80 for a oil pressure sender at the dealer
I prefer to us ACDelco/OEM parts when replacing,
Thanks for putting this together
Neal
Old 05-04-2018, 05:32 PM
jsbihn's Avatar
subbed in
Old 05-10-2018, 12:34 PM
Baldfox's Avatar
Gm "Green" Keys General Motors, ARM, 15592573
Amazon Amazon
Dynatech Headers 2008/09
Amazon Amazon
LED Headlamp Conversion Truck-Lite 27270C 7" Round
Amazon Amazon
Truck-Lite 98630 LED Headlamp Anti-Flicker Module Harness - PWM Pule Width Modulation Adapter
Amazon Amazon
aFe Air filter (dry)
Amazon Amazon
aFe Air filter (oiled)
Amazon Amazon
Old 05-10-2018, 06:55 PM
madmayo's Avatar
Nice. Thanks
Quick Reply: Amazon parts
