All-terrain tire for traveling
Currently I have 37" toyo MT but I may potentially start using my H2 for more highway use. I've been comparing different All terrain tires to get a better ride/mpg and better in ice/snowy conditions.
Does anyone have a recommendation? Or should I just stick with the toyos and wear them down? I'm thinking it might not be worth swapping tires at all.
The other issue is that some of these good AT tires arent made in a 37" so I may have to drop down to a 35 and I'm not wanting to give it a wierd look with smaller 35's paired up with my Cognito UCA kit, traxxda key lift, bilstein shocks, etc.
Another thing I just thought of if i went back to 35s would be regaining the lost power from moving to 37's without regearing... so that might be nice.
I like the look and performance of the Nitto terra grapplers in 35"
thanks for input...
thanks for input...
The Nitto's actually have a pretty aggressive tread pattern for being an AT, I actually really like them. I've been looking for wheels and was going to throw MT's on mine but I think the Nitto AT's or Toyo AT's look mean and will probably have a much higher life.
Well i went to discount tire and found out a few things
the 37" terra grapplers are on national backorder, so unless you can find some on ebay or something you'll be waiting a long time.
Toyo AT's are discontinued (i asked about the 37's)
I've decided to go with the 325/70/17 Nitto Terra Grappler since it actually measures out at 35" in diameter and it still looks pretty aggressive for an A/T. Looking forward to better handling and ride in all conditions vs my current toyo M/T
