Air Ride Suspension randomly drops
I am stumped I have an 03 Hummer H2 with 60K that randomly squats down when it sits. If i back it into my driveway so the front is angled down nothing, but if I drive it in so the back is angled down by the next morning its squatting. I went under the truck with a spray bottle and soap and soaked the airbags and didnt see anything.. Could it be a bad line and how hard is it to check them?
Hutch
Hutch
Just gotta soak everything. sucks. on the bags try getting the rear end in the air..lift it with a jack so it extends the airsprings then spray. mine was leaking in the folds and sealing itself when level. it only leaked when not level.
Hutch
Hutch
Had a great job done on my springs (had small leaks in both bags). I only tow my Tahoe Q8 ski so no issues yet . But my air suspension caused one issue after another, and when it went down the last time, it looked like a car from a WAR video and rode like a stagecoach, hence my choice of steel coils. Great ride, more dependable thus far, and no mo low ridah!
The compressor is alot of money. thats why when your bags leak you fix them right away. If you don't, and let your compressor run all the time to keep the bags inflated, you will burn out your compressor. There are many threads on this forum about this issue.
SAH2 I tow a trailer that is at my max tow weight when I go camping and wheeling about once a month. the compressor is a must for me to reinflate my tires, level the rear end and blow up mattresses etc. If I remove it, I'll still need to buy another air tank or something like that.
It is the bags or a line (I had both). Raise the bags to the extra hight and spray them again. Almost sure it is bags since they dry rot.
I replaced with new bags, hoping the compressor is still in good shape. So far so good.
I love airsuspension. I had it on my VW Touareg too. Great when towing
The spring kit $170... You can do it yourself in an hour. There is a YouTube video on how to.
Hummer H2 Rear Suspension Air Bag to Coil Spring Conversion Kit : Amazon.com : Automotive
if you buy this spring kit can you still lift the vehicle after? has anyone tried? i am having similar problems and also want to buy a rancho lift kit. does this converison kit screw with anything? do i purchase the kit that asks if you are running springs or air?
itsxthexslim
04-07-2012 11:04 AM
XxCC3xX
08-23-2011 02:05 PM
myrddin
28
08-12-2010 05:46 AM
