Originally Posted by OCFDfyrfytr
(Post 413585)
Thank you for your time. Yes I bought this 08 SUT new yet used the ELECTRIC button. Please assist, often i must use this ELECTRIC button to raise the SUT, as the air bags are going down every few days. Any thoughts what to do or where to send. Seller dealership stated R7R to springs/ NO!!! h a
Once these shocks get to around 100k miles, they tend to fail and need to be replaced. Replacements are around $300 each, so $600 if you're going to DIY. It's a simple job - just 2 bolts, an electric connector, and the air hose. |
What is the ELECTRIC button?
Is this some aftermarket switch that pumps air into the bags or has the Air Suspension Unit been modified? |
Replace the air bags as they are not that expensive & its fairly easy. JUST keep in mind, the air pipes (plastic lines) that quick connect into the bags may be the area you are leaking at also.... others may have a way to check with soap & water misted. If I remember right you can remove the rear fender liners to squirt (I may be wrong- Im old and has been a few years since I have replaced mine.... (this is my 4th H2, done on all prior that had air suspension). If I remember correctly you can get both bags under a couple hundred dollars....
| All times are GMT -5. The time now is 11:04 PM. |
