Air ride button on the dash H2
Old Feb 11, 2025 | 01:15 PM
  #21
HellHoof's Avatar
Originally Posted by OCFDfyrfytr
Thank you for your time. Yes I bought this 08 SUT new yet used the ELECTRIC button. Please assist, often i must use this ELECTRIC button to raise the SUT, as the air bags are going down every few days. Any thoughts what to do or where to send. Seller dealership stated R7R to springs/ NO!!! h a
All GM vehicles with the rear auto-leveling shocks will sag after sitting for days. When you turn the key on though, after about 30 seconds the air compressor should kick in and auto-level the truck back up.
Once these shocks get to around 100k miles, they tend to fail and need to be replaced. Replacements are around $300 each, so $600 if you're going to DIY. It's a simple job - just 2 bolts, an electric connector, and the air hose.
Old Feb 11, 2025 | 07:20 PM
  #22
oceanbrave's Avatar
What is the ELECTRIC button?
Is this some aftermarket switch that pumps air into the bags or has the Air Suspension Unit been modified?
Old Feb 12, 2025 | 01:57 PM
  #23
Chrmer3's Avatar
Replace the air bags as they are not that expensive & its fairly easy. JUST keep in mind, the air pipes (plastic lines) that quick connect into the bags may be the area you are leaking at also.... others may have a way to check with soap & water misted. If I remember right you can remove the rear fender liners to squirt (I may be wrong- Im old and has been a few years since I have replaced mine.... (this is my 4th H2, done on all prior that had air suspension). If I remember correctly you can get both bags under a couple hundred dollars....
hkench
Dec 18, 2021 06:04 PM
myrddin
28
Aug 12, 2010 05:46 AM
tugboat patti
Sep 15, 2008 07:18 PM
valleygirl3000
May 1, 2008 05:58 PM
