air lift suspension
Old 10-18-2007, 10:41 PM
kseaman's Avatar
Default air lift suspension
Does anyone know of a good place to purchase replacement air bags for 03 H2, sometimes mine will leak down over night...
Old 10-19-2007, 05:04 AM
hilljob26's Avatar
Default RE: air lift suspension
are you sure its your bags and not your line
Old 10-19-2007, 05:05 AM
hilljob26's Avatar
i would get a spray bottle,fill it up w/ soapy water,spray as much of the bags and the line that you can see,it will start foaming,then you will know where your problem is
hilljob26's Avatar
it might even be just a fitting
Old 10-20-2007, 09:14 AM
Is it still under warranty?
Old 10-20-2007, 09:15 AM
If it is then you can go to the dealer and get it fixed
Old 10-24-2007, 09:02 PM
kseaman's Avatar
thats a good ideal, I will try it this weekend.
thanks
the left one has alot of weather cracks, so it could be the problem..
Old 11-09-2012, 04:04 AM
jopuhiysilo's Avatar
If it is then you can go to the car dealer / car repairer and get it fixed but i haven't heard of this problem from any of the friends ....... well never mind and no offense i mean here.... i guess you will probably find a better solution for it by yourself::::
Old 11-09-2012, 10:58 AM
nlhummer's Avatar
You can buy them on ebay for about $160 a piece.
The place that replaced mine charged me $180 a piece and they came from a GM dealer. Installation for both is 1.6 hours total.
$20 for diagnostics plus a $35 relay plus 20 min labor for install of relay plus taxes made it $590 in the end.
Old 11-15-2012, 02:14 PM
THIS IS A "DO NOT POST" SECTION!!!!!!!! and an older than dirt thread.
Quick Reply: air lift suspension
