-   Hummer H2 (https://www.hummerforums.com/forum/hummer-h2-8/)
-   -   Advise on buying a 2005 H2 (https://www.hummerforums.com/forum/hummer-h2-8/advise-buying-2005-h2-40217/)
Hbrezzi 09-09-2018 01:28 PM
Hello all,
first of all I’d like to say hello to everyone as I am new to this forum.
I am am looking at buying a 2005 H2 but this are the issues with this particular beauty:
Pros:
- Great overall conditions in and out
- Brand new tires
- Engine sounds and runs great
- Shifting is smooth
- No rattles
Cons:
- Instrument cluster not working properly
. Odometer not working
. Brakes, ABS and engine lights are on
. Revs and speed are stuck 500 rpms and 30 mph
- It takes about 5-6 seconds for the reverse gear to engage.
- Possible leak in the air suspension
- A/C doesn’t work properly (it might be just a gas issue)
Warning messages:
. Service Trac 4 wheels
. Service air suspension
. Change engine oil
My mechanic performed some tests with a scanner and this is what he says:
- Engine oil pressure too high (almost twice the pressure ??)
- Actual mileage is 175.000 and not 108.000 as displayed in the odometer.
Having said this... Owner wants $10.500 for the H2. Here in Panama there are only about 3 for sale for $15-20k. I am old enough now to afford this vehicle and to fill it up ;-) and this has been a dream of mine for the past 15 years!
Price is non negotiable...
A friend of mine in the US tells me that all the above described issue could be easily and inexpensivley resolved as they could all be related to the use of improper oil in the transmission and some bad ground wiring contacts. The mechanic here (not familiar with hummers) tells me to run away... What would you guys do? (Worst case scenario, I have a $2000 - $3000 budget for repairs).
Thanks in advance for any help!
Hoff 09-09-2018 02:30 PM
Have you looked at the other H2’s in you area yet? With the firm $10500 and you repair budget, I would check the others out first?
hummer_on_fumes 09-09-2018 02:47 PM
Originally Posted by Hbrezzi (Post 354465)
Hello all,
Pros:
- Brand new tires
- No rattles
Cons:
Warning messages:
. Change engine oil
Instrument cluster and odometer are an easy fix, there are eBay sellers that refurbish them or YouTube videos on how to repair them yourself
air suspension can be converted to coil springs
brake/abs/etc could be the ebcm which also needs refurbishing, would need more details on the actual codes
A/c is not that difficult to fix
The main flag that would worry me is why is the odometer so far off? In the US you'd have issues with titling it.
Hbrezzi 09-09-2018 02:58 PM
Hello hoff,
Unfortunately, of the 3 H2’s available in the local market, this is the only one in great exterior/interior shape. Of the other 2, 1 is a SUT and the other one is pretty beat up and needs new tires...
Hbrezzi 09-09-2018 03:04 PM
Thanks for your input. Essentially I agree with you and that’s why I’m still considering buying it. What worries me the most is the reverse gear and a possible imminent transmission failure. Of course I’d start by flushing it and using the right D VI fluid.
You are right about the odometer. I will run a VIN check to see what issues this H2 had in the US before being brought to Panama.
So, do you think my repair budget could suffice given the the current symptoms?
Hbrezzi 09-09-2018 03:08 PM
By the way, this is the H2 I’m looking at (the 2nd set of rims and tires are included in the price 😂)
https://cimg3.ibsrv.net/gimg/www.hum...b2850f218.jpeg
https://cimg4.ibsrv.net/gimg/www.hum...12dd0e50d.jpeg
https://cimg5.ibsrv.net/gimg/www.hum...cc20afe32.jpeg
https://cimg6.ibsrv.net/gimg/www.hum...a35aa6b22.jpeg
https://cimg7.ibsrv.net/gimg/www.hum...c29302bbf.jpeg
https://cimg8.ibsrv.net/gimg/www.hum...6326c69d2.jpeg
https://cimg9.ibsrv.net/gimg/www.hum...3f1b3e9c0.jpeg
https://cimg1.ibsrv.net/gimg/www.hum...449c13f8b.jpeg
https://cimg2.ibsrv.net/gimg/www.hum...93ce31537.jpeg
https://cimg3.ibsrv.net/gimg/www.hum...ff3cd922b.jpeg
Hoff 09-09-2018 06:55 PM
Sure looks nice! If most items are a easy fix, I would probably get it, especially knowing that nothing is avail in your area.
Hbrezzi 09-09-2018 07:11 PM
Glad you liked it. Since you insist.... LOL Then I'll probably just cross my fingers and get it!
MixManSC 09-09-2018 07:20 PM
I'd ask if they will take some money off to keep the giant wheels with rubber bands on them. If not I might offer to pay them some extra just to keep them. It will ride like total crap with those. That also gives me pause regarding the transmission. If those are considerably larger diameter with the tire than the stock wheels, they have been putting a huge strain on the transmission trying to make them turn. The transmission hesitating to get into reverse makes me worry even more. That can also account for the mileage discrepancy as well - if those were on it for a long time and the PCM was not calibrated for the larger tire size than both the speedometer was incorrect and the mileage will be recorded wrong.
Hbrezzi 09-09-2018 07:32 PM
I Agree 100%... I would never ever consider using those giant wheels! You are absolutely right about what they could have done to the tranny... I didn't even think about it. And yes, the transmission is what worries me the most...
