2nd gear slip?
Old 02-05-2015, 03:56 PM
mardom1's Avatar
Default 2nd gear slip?
I have a 08 h2 sut, when rolling just over 10 mph after it has shifted into 2nd gear (i think) when i accelerate i feel a sleight bang. Is my trans slipping? Or am i just paranoid?
Old 02-05-2015, 07:46 PM
calif phil's Avatar
You could have a bad u joint but it's not a slipping tranny.
Old 02-05-2015, 09:20 PM
Signal25's Avatar
Bad trans mount?
Old 02-06-2015, 07:33 AM
mardom1's Avatar
never thought of the u joint, thanks i will check on that
Old 02-06-2015, 08:54 AM
MVR 155's Avatar
This is very typical of GM trucks/SUV's with the 6 speed trans. I have brought mine in a number of times complaining about the clunk on throttle tip in after deceleration. Back at the beginning they did a reflash which helped a little bit, last time I was in I mentioned they look at things again. I'm not happy with the low speed manners of the 6 speed...... the closer gear ratios and extra gears help considerably with acceleration and towing but I wish it behaved a bit better at lower speeds.
I have a PDF of the paperwork/bulletins the dealer gave me regarding the issue but the file is too large to upload here (you can only upload a 19.5kb PDF file and my file is right at 300kb). If you would like I can email it to you.
12-18-2014 10:17 AM
jasonsdad
09-19-2011 07:41 PM
blueh2
09-28-2010 05:53 PM
PolishH3
09-27-2009 06:22 PM
Brandon07
10-02-2007 07:31 AM
Quick Reply: 2nd gear slip?
