3 Attachment(s)
You can get the hubs here Timken Bearings (NEW + Kryptonite) [SP580310-SP580311-580312-58013] - $199.99 : DMAXSTORE.COM, Your Duramax Diesel-Only Shopping Resource They are $199@ which is what you would pay for cheap ones at a parts store. The wheels and tires in the pics are Fuel Hostage 22x14 with 35" Toyo MT's. I don't recall what the offset is. They stick out about 3". If you want aggressive looking MT tires, the Toyo seems to last lnger than others. The 40" Toyo MT's lasted about 65,000 miles on my lifted H2 and that's with a lot of off roading. You will need good hubs regardless if you stay stock or not. Beefing up the steering and suspension components is a good idea too. On my lifted H2 I have Kryptonite tie rods and Moog Idler & Pitman Arm and ball joints. You can find a lot of good stuff on the site in the link. I got the ball joints seperately and pressed them into the stock control arms just because I don't see what difference a control arm itself is going to make. Some places sell the control arm with the ball joint already in it to make it easy on you. I haven't done anything with the bushings as they have lasted pretty well. The 22" wheels and 35" tires aren't going to wreak much more havoc than the stock will.
at 100$ for all direction parts, why not change them all once a year or every two years ? if you ca do it yourself, why not put the rims that you like ?
BALL JOINT TIE ROD HUMMER H2 03 04 05 06 PITMAN ARM IDL | eBay |
Originally Posted by Caraddict
(Post 290043)
I like the hash marks on your fender...where did you get them?
If you like I could do some for you. |
Originally Posted by KruBruder
(Post 291022)
I will look into that. Do you know if the cognito arms are a good upgrade? From reading it seems like they would be beneficial to have. I would probably need to raise the front a little and I found a cognito kit that also included shock mounts to reposition the shocks if you raise it using torsion keys. Also they say you get more comfort and more caster using these arms. What do you think the kit is like $600 |
thanks again for all the comments
Originally Posted by Chief qc
(Post 291029)
BALL JOINT TIE ROD HUMMER H2 03 04 05 06 PITMAN ARM IDL | eBay On the Cognito Control arms....I don't know enough about them to say if they are or are not worth the $600. My guess is that if you stay on the pavement(or snow), you probably don't need them. My wife's H2(the one in the pics) is leveled but the guys at the tire shop just torqued the torsion bars without changing the keys when they put her wheels on. I hear it's probably better to get the leveling kit with the keys but I don't know for sure.:confused: |
4 Attachment(s)
Update..
So I went back to the tire shop and fitted some FUEl Octane in Chrome 20x12 with a Toyo 35/12.50/20 MT. I think the Black looks better for some reason.Attachment 13107 Then I had them mount two of those 20x14 Fuel Hostage Attachment 13108 I decided that although the 20x14's look sick IMO, they are going to probably damage the suspension very very fast. I went to another shop who reccomended me some 20x10's 2 crave nx-1 wheels they mounted them up on some Nito Mud Grapplers and it did look very nice. Not sure if it looked nicer because of the Nito aggressive tire design or the combo. I did not get a chance to snap a picture of them on :( but, this is what the design of the wheel looks like. Attachment 13109 Attachment 13110 The guy there said I would probably be safest with a 20x10 wheel. I am a little worried about the Nito Mud Grapplers being to LOUD. I had some Irocks on my Avalance and I did not mind the noise but, after a while the vibration kind a got to me. THings rattled in the cab after a while so I switched out to some Cooper Zeon LTZ's and those were super quite..I wonder if the Mud Grapplers will be as noisy as the Iroks??? Still not sure what direction to go but I am glad I tried on the 20x10 because it really has made me reconsider going that direction. I am also thinking about some XD Armors, anyone have them on their hummer? Also considering Rockstars but in a 22x10 or 22x12. Any thoughts?? |
1 Attachment(s)
Well I ended up ordering some of the new KMC XD 809 wheels in a 20x10, just in case anyone was curious hahaha this thread is kinda dead....
Attachment 13103 |
I think the tires look too small for the vehicle also. But you need a set of one of the following to counter the width issue. I am thinking about install them on mine I am running Toyo 37/135.-24's which rub by the way.
Hummer H2/SUT Fender Flares by Street Scene Hummer H2 Wide Body Fender Flare Kit by E&G - Ready To Paint |
37/13.5 24's I meant. I order a set of 2" wheel spacers so I can park the darn thing without tearing up a tire.
| All times are GMT -5. The time now is 09:52 AM. |
