2006 H2 Temp Control not working right
Old 01-15-2013, 01:22 PM
maxwellmark's Avatar
Default 2006 H2 Temp Control not working right
Hello, I tried searching but could not find my issue anywhere. My lights all work and the actuator works but the control dials don't (mostly driver side)
I have to pull out slightly on the temp control dial and turn 1 click at a time....very slowly. Just to get the digital temp display to change correctly (sometimes this works). If I just turn the dial the display jumps all over the place from 70 to 87 to 68 etc. Is this a problem with the whole climate control module, or can I just replace the dials?
Thanks in advance,
Old 01-16-2013, 05:12 AM
LoJac963's Avatar
I'm sorry but I cannot remember what the dials looked like when I had my climate control apart to replace the bulbs with LEDs. If its the same as the radio which it probably is you'll have 4-5 solder points for the contacts and another 3-4 solder points for anchors. They are a pain to desolder especially the anchor points but it wouldn't be impossible by any means.
Here is a pic of the radio for reference of what I'm talking about:
I wish I would have taken more pics when I had litterally every switch and circuit board taken apart in the interior.
Old 01-16-2013, 05:14 AM
LoJac963's Avatar
oh if you take on this venture I highly recommend a no clean flux solder wick. Radio shack sells them by 5 foot rolls for 8 bucks I think. It will make that project so much easier then trying to just warm the solder and pull the points out.
Old 01-16-2013, 08:10 AM
1979ccf0233's Avatar
I am having the exact same problem on my 03 H2...temp jumps all around and very hard to set. Have to turn riciculously slow to adjust. I am looking for a replacement module but would love to find a cheaper solution.
tylenol7
01-20-2015 10:59 PM
RadioMike
06-16-2014 03:13 PM
JensH2
12-14-2013 02:27 PM
Flashawd
01-15-2012 09:34 PM
No more Jeeps
01-11-2011 05:34 PM
Quick Reply: 2006 H2 Temp Control not working right
