2006 H2 Nav will not working when vehicle is moving
2006 H2 Navigation system will not work when vehicle is moving, only when it's at rest - Works fine when stopped.
Does anyone know what setting to change or other suggestions?
Thanks,
Rob
Thanks,
Rob
Its a safety feature, at least I'm assuming. None of the vehicles I've had with nav would let you mess around with it while moving to prevent you looking down and playing with the screen when you should be looking at the road.
Yelp, the NAV sense when the vehicle is moving via the VSS wire.
You can wire in a switch that turns it off and off if you are inclined.
I am 99% sure its the '05s and up that have the VSS wire.
'04s and down are not so lucky.
I hope this works...
http://www.performancetrucks.net/for...0/#post4858034
TxHummer07
03-22-2015 11:02 AM
JensH2
12-14-2013 02:27 PM
Flashawd
01-15-2012 09:34 PM
Flashawd
07-13-2011 10:26 PM
TSS HUMMER
08-18-2010 12:01 AM
