2000 6.0 to 2006 4l65e. Canít mate up
Old 05-16-2019, 07:42 PM
Default 2000 6.0 to 2006 4l65e. Canít mate up
So my H2 engine was having problems. I found a 2000 6.0 with low miles. Did my research found I needed a 6.0 with the 8th digit U. Got the engine In and started up no issues using the original transmission (my h2 is a 2005). BUT. IT wouldnít go into any gear. The common census was when putting the engine in we messed up the oil pump and it had high mileage. So went and bought a newer tranny with lower miles. Brought it home but they wonít mate up. After several attempts we found this
Different from their Chevy predecessors, most of the Gen III engines (see chart, below) had a shorter crank flange, offset of about 4/10" closer to the block. This is not an issue when working with original-configuration GM powertrains, but must be addressed when mixing different iterations of GM transmissions
so with that being said is there anyway to get an engine from a 2000 6.0 to mate up with a 2006 4l65e?
Old 05-17-2019, 08:31 AM
MOVED from the Drivetrain Area where it says: "This section is an archive of older posts, please post new questions in the specific model section. Thank you!"
You answered your own question. Don't mixed different generations of powertrains.
If Advance Adapters doesn't make an adapter, do not know where you could find one. Go to their website, create a login account, and search by vehicle profile.
Good luck.
Old 05-17-2019, 11:45 AM
They have different input shafts. You need a torque converter with a 300 mm shaft, the 60e has a 298mm.
Tim
Old 05-17-2019, 11:46 AM
have you compared both bell housings? some older model transmissions are one piece also i believe the bell housing on the H2 is a bit deeper to take a deeper torque converter.
Old 05-17-2019, 06:36 PM
Maybe this will help you found out exactly what you are working with and what you need to fix it. I think it’s just a spacer.
The Novak Guide to GM Gen III+ Engine Crank Spacing & Interchange
dartdart
04-06-2016 06:00 AM
fortknox82
12-28-2013 07:33 AM
gdaskal3
General Hummer Talk
06-25-2013 06:28 AM
shegodemona
Hummer H1
01-19-2010 02:08 AM
Zmf203
Private 'Wanted' Classifieds
06-02-2006 01:08 PM
Quick Reply: 2000 6.0 to 2006 4l65e. Canít mate up
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
