150k mileage checkup suggestions?
Old 05-16-2017, 12:30 PM
dkb123's Avatar
Default 150k mileage checkup suggestions?
Anyone have any obvious suggestions for an H2 checkup at the 150k point? Already had/fixed the ex manifold issue. Just took the truck back from an employee and dont think he's done much maintenance.
Thanks ...
Old 05-17-2017, 08:12 AM
calif phil's Avatar
I would do, front and rear diff service, trans filter change, have the front end and u joints inspected. That should be a good start.
Old 05-17-2017, 08:38 AM
dkb123's Avatar
Thanks ... will add to my checklist ....
Old 05-17-2017, 12:56 PM
dontheo55's Avatar
Default Bushings
More of an item than inspection. If you have not done so yet I would start replacing all the bushings in the suspension and Steering. You will be pleasantly surprised.
Old 05-17-2017, 05:20 PM
dkb123's Avatar
Thanks .... adding to my list ....
I seem to have a lot of corrosion on the underside. More than I would expect. I have a 3 year older dodge that exhibits none of this. The dif cover in the back needs to be replaced for example and the transmission lines are pretty rusted up. Is this typical of the speciesor just mine?
Old 05-21-2017, 08:22 AM
NoSpoon's Avatar
Check and/ or replace all brake lines. If you have rust your brake lines are probably in sad shape.
Old 05-24-2017, 11:24 AM
dkb123's Avatar
Yep ...mine were replaced a few thousand miles ago badly rusted. Not actually confident it was done properly ... looking into it some more.
Thanks ...
Old 05-24-2017, 11:25 AM
dkb123's Avatar
Default bushing kit source?
Hey - I'm working with my mechanic on your bushing suggestion. Is there a good source for a kit on this or do you need to buy them all individually?
Hoping to save some time ...
Thanks ...
Intercooled
16
04-14-2007 04:22 PM
Trey124
02-22-2007 02:33 AM
HummerGuy
08-07-2006 02:44 PM
importkiller
06-20-2006 05:36 PM
Sisco22
05-12-2006 02:48 AM
Quick Reply: 150k mileage checkup suggestions?
