vin # check results... is this bad?
This is whatwasretreived for my 97 Wagon, seems like a lot of work to me, but what do you guys make of it all:
2.20.97 259 MILES
REPLACE GLOW PLUG
REAR CHASSIS HARNESS
FUEL GAUGE
RIGHT SUNVISOR
3.24.97 2897 MILES
L/F HUB SEAL
FRONT TOE SET
GLOW PLUG
REAR OUTPUT SHAFT SEALS
REAR BRAKS AND A ROTOR
4.15.97 5987 MILES
O RINGS FOR MAIN A/C UNIT
SUCTION, A/C HOSE
10.27.97 12008 MILES
ALIGHN EXHAUST, HOOD
12.5.97 13582 MILES
REPLACE HYDRAULIC BRAKE BOOSTER
2.20.98 16124 MILES
TRANS CASE RECON, COOLER LOOP
LH ROCKER COVER GASKET
3.26.98 17379 MILES
FUEL PUMP
5.5.98 18150 MILES
VACUUM PUMP
10.15.98 20000 MILES
T-CASE PLUG
AMBIENT TEMP SWITCH
TRANS DIPSTICK TUBE SEAL
PITTMAN AND IDLER ARMS
LEFT OUTPUT SHAFT SEAL
FRONT ROTORS
10.12.01 29956 MILES
FUEL DRIVER SOLENOID
2.20.97 259 MILES
REPLACE GLOW PLUG
FUEL GAUGE
RIGHT SUNVISOR
3.24.97 2897 MILES
L/F HUB SEAL
FRONT TOE SET
GLOW PLUG
4.15.97 5987 MILES
SUCTION, A/C HOSE
12.5.97 13582 MILES
2.20.98 16124 MILES
3.26.98 17379 MILES
FUEL PUMP
5.5.98 18150 MILES
VACUUM PUMP
T-CASE PLUG
AMBIENT TEMP SWITCH
FRONT ROTORS
RE: vin # check results... is this bad?
Nothing major there - seems like a lot of replaced seals early on, and more failures than usual (fuel, hydroboost, vacuum pump) but nothing to panic about. The t-case cooler loop is a routine/upgrade, same with the t-case plug. Idler and Pitman wear is common.
H1s required regualr service and maintenance. That is part of the deal when you buy one. Nothing on that list scares me at all. No service records beyond the ones you posted? Engine swap, HVAC replacement, etc?
ORIGINAL: 3hummers
Sure I understand they require maint... I spent 6 years in the Army, actually worked in the motorpool too with all the HUMMVS. Unfortunately for me it was in the supply field ordering all the replacement parts for them and not actually working on them. As a driver was required to do a weekly and monthly PMCS (Preventative Maint and I can remember the "C"Schedule). I plan on buying the maint CD to help me.
Nothing past what I put up above, how could I get further records? I askedthe dealer (not a hummer, just a used car place) to talk to previous owner and see about service records on it. No updated HVAC though cuz I have the old style control panel with the 2 buttons on it (a/c and retriculation).
Not sure on the engine... I did get a 4 yr 100,000 mile additional warranty on the engine (including turbo) transmission, and all gaskets and seals (not sure if its for the whole truck or just the engine though) for $1000 well worth it I am sure.
I love my 97 wagon. It was my DD for awhile. Now it is my trail truck. I have the original HVAC and block and have had no real issues. Normal stuff, a few T case rebuilds, ***** joints, etc. It has been a real good truck. I think you will really like yours.
HumminNBoatin
04-24-2008 03:10 PM
HummerGuy
30
09-01-2006 12:17 PM
