-   Hummer H1 (https://www.hummerforums.com/forum/hummer-h1-16/)
-   -   Tire Change on Hutchinson Alpha Wheels (https://www.hummerforums.com/forum/hummer-h1-16/tire-change-hutchinson-alpha-wheels-49255/)
abovethelaw823 Nov 18, 2025 01:15 PM
Looking for recs on a tire shop in Los Angeles who has experience changing tires on Alpha wheels. Also, how much did you pay?
3hummers Nov 21, 2025 02:12 PM
Don't know about LA. I always took my two Alphas and all my other H1s to Mike Sabaresse at Tustin GMC/Hummer. Mike is still there and Tustin GMC does a robust H1 service business.
abovethelaw823 Nov 21, 2025 02:22 PM
Thanks. I recall the last time I spoke to them (~2 yrs ago), they couldn't do it. But, I'll reach out again to confirm.
3hummers Nov 26, 2025 02:34 PM
They can they just may not have wanted to at the time. Tell Mike his good buddy Dave from Texas sent you there.
Might also try Hummercore. They might know someone in your area that will do them.
abovethelaw823 Nov 26, 2025 02:43 PM
Yes, I have checked there too. The problem is that the labor gets in to the thousands (plus about $2k for the tires). I know this is the primary reason that people take off these wheels and put on aftermarket wheels. Just was curious to see if anyone had a shop that had experience and was reasonably priced.
linel Feb 24, 2026 02:21 PM
Originally Posted by abovethelaw823 (Post 417750)
Yes, I have checked there too. The problem is that the labor gets into the thousands (plus about $2k for the tires). I know this is the primary reason that people take off these wheels and put on aftermarket wheels, especially when working with BMW 1 Series parts. Just was curious to see if anyone had a shop that had experience and was reasonably priced.
If you’re looking for a tire shop in Los Angeles experienced with Alpha wheels, VIP Exotic Wheels, Davis Bros Tires, and Melrose Tires Wheels & Hubcaps are solid options. Prices for mounting and balancing typically run $20–$40 per tire, though larger or run‑flat tires can cost more. Always call ahead to confirm they’ve worked with wheels like yours and check if TPMS service is included.
abovethelaw823 Feb 24, 2026 02:33 PM
Thank you!
3hummers Feb 24, 2026 04:06 PM
Last Alpha tire change I did ran about $100/wheel.
abovethelaw823 Feb 25, 2026 04:44 PM
Which of the 3 shops that you mentioned was this at?
