T/C green light not coming on.
Old 05-03-2011, 07:06 PM
ozsmo's Avatar
Default T/C green light not coming on.
I need help with my H1. The T/C green light does not come on when I put it in HL or L. This means to me that it is not locking the diff. in. So to check it out I put in HL on the street to see if it would bind up some as I turned the rig in a circle and it went way to smooth. Most 4x4's will buck at that move, any ideas on things to check out?
Old 05-06-2011, 12:03 AM
Tranny in neutral, pull TC lever hard to the L. There should be a clunk. Light should come on at the point. Is that what you are doing?
Old 05-06-2011, 11:19 PM
ozsmo's Avatar
Default t/c lock light
Thanks for getting back to me. I believe the case is going into L or at least it is in low range, the light is just not going on. I had some one send me a diagram of t/c case with the location of the t/c lock-indicator switch so that will be my next step. I hope that will be the fix?
kingguitar
02-11-2014 09:48 PM
atomicgoofball
07-13-2011 05:08 PM
mrkodo
12-27-2008 10:01 PM
solarflare
01-05-2008 08:16 PM
schannel
08-17-2007 03:30 AM
Quick Reply: T/C green light not coming on.
