H1 Stuck in Park
Hi, My H1 is stuck in PARK. I have replaced the brake switch at the pedal arm; checked all fuses and relays, removed transmition shifter cable and manually shifted the truck in gear to back into my garage. Then disassembled the dash and shift lever covers looking for a secondary switch, relay or silinode but haven’t been able to release - shifter. Does anyone have experience with this ? Oh yes I initially had another vehicle push against the Hummer to release pressure as instructed in the owners manual. Any ideas out their ? |
Welcome to HF.
I MOVED your post tacked on the end of an old irrelevant thread in the wrong section. If you have questions about an H1, post it in the H1 section. |
