| wmartin21 |
Aug 19, 2019 03:17 PM |
H1 Hummer with key stuck in ignition won't turn to lock
I have a 2003 H1 Hummer and for some reason the key will not turn to lock or come out of the ignition. It sometimes would do this but with a little bit of wiggling it would pop right out but now it is STUCK!! I've tried moving the gears around, moving from HL to H to L, etc. What do I do? What is causing this? Also, my CTIS tires are starting to deflate to being FLAT when I drive it only!! If it's in the garage it's fine. It's technically just one tire but thought I'd mention it. I live in a rural area where I can't just pop on over to my local mechanic for a quick fix. I need a specialist magic mechanic to work on these beauties!! Thanks so much!
