1997 6.5LT rear differential leaking at input between draft shaft and differential.
Need the specific set of parts needed to replace the seal and or bearings for full service. Only has 80k miles on it but leaking, not bad but can see where gear oil is coming out.
Talk to Dave Oberer at www.hummerpartsguy.com. He can fix you up with everything you need.
| All times are GMT -5. The time now is 02:44 AM. |
