Help
Old 06-30-2011, 05:07 AM
RGray711's Avatar
Default Help
BACKED MY 08 ALPHA INTO MY PARKING SPOT THIS MORNING AND CAN NOT GET IT OUT OF REVERSE?
Old 06-30-2011, 01:10 PM
RGray711's Avatar
Never mind dealer came and got it Thanks:
Old 07-12-2011, 02:27 PM
RGray711's Avatar
Just in case someone has this trouble it was shifter cable separation .
And they had to order the cable took about a week all is good now.
Old 07-12-2011, 02:40 PM
Thanks for posting the "fix" for your issue! That is what makes this forum helpful. Not only asking a question but coming back and posting an answer that fixed the issue!Did you happen to get any pix of the old shifter cable that separated? Where did it separate from (the trans or the shifter). Inquiring minds would like to know.
THANK YOU!
Old 07-12-2011, 10:26 PM
drtom's Avatar
Banned
Default it was shifter cable separation .
id sure like to know more about exactly what happened. the "hard"lock in park is a small solenoid/pin that blocks the shift lever. i taped mine in so i can shift anytime,no key,no batt,no nuttin. you know,if youre on the train track and dont want to see your ride get smashed!!
so im thinking?? was it really?
btw when you push the brake you should hear the solenoid move, you can "fix"it!
Old 07-13-2011, 05:48 AM
RGray711's Avatar
Understand the train track they said the cable just broke into.
On the up side when our AWD hummer is stuck in gear turn it off
and the driveline goes to neutral.
Old 07-13-2011, 10:16 AM
drtom's Avatar
Banned
im thinking that IF the cable broke,AND the solenoid was activated,the shift lever would move but not shift out of park or any gear. did the lever move freely? if not the problem was the ?solenoid or control switch/brake.
Old 07-13-2011, 10:49 AM
RGray711's Avatar
You could hear the solenoid activate but could not push thumb button in and was unable to move lever with both hands. by the way it was in reverse when the cable broke and that is were it was stuck would not move period.
Old 07-13-2011, 12:12 PM
drtom's Avatar
Banned
Default could not push thumb button in
i forgot abt that!,,,now i need to check some stuff. i do know that i can open the door with key,and then shift anywhere.
i dont at this minute know what stops the button,but im sure i can push it and shift,,,?
assume the sol? which i disabled,,,later ,,,yeah the sol
importkiller
29
01-15-2008 02:51 AM
Quick Reply: Help
