adjust play in the sterring wheel
I was looking on yube tube on how do tighten the play in the steering wheel. I have a little play but the process does not look hard. Says to loosen the nut and use allen head to adjust. Anyone done this first and helped or should I look at other problems?
Welcome.
First .... this section is NOT for vehicle questions. It is to ask about how to use the features of Hummer Forums itself. Like "How do I post a picture?" .... Next, if you are asking a vehicle question, it goes in the Vehicle Section. If you have a question about and H3, then post it in the H3 section. Last, whenever you ask a question, you need to include year & model. For instance, 2007 H3 Adventure, so people might actually be able to respond with useful info instead of wild guesses. So good luck. |
oops, thx doc.
