Torsion lift - Pics and How To
Are there any worries about premature balljoint wear by doing this?
When I had my ZR2 (1999 S10 version), people would do this, but it would cause premature wear on other parts (IIRC, balljoints)...Different animals, I know, but same suspension concept...
Obviously, an alignment, as mentioned, would help, but just wondering what the long term effects, if any, are...Looks good though, levelled!
The S 10s needed a redesigned upper A arm to get away with it. My old truck had a superlift set.
H3s do not have those issues. So long as you stay at/below 23.5" from the center of the hub to fender, you are good. You can adjust as little or as much as you want within that limit. 24K on mine, not a problem, others with 50 and 60K, no worries.
Anyone have any issues turning their bolt till they can't turn it anymore and it only being 22" from center of hub to fender... (Drivers Side).
Can I back off the drivers side, crank up the pass side, then try the drivers side again or are they strictly separate and have no impact on each other?
Was going to do it myself. know i would need an alignment after so took it to the dealer and let them adjust the bars then align. i asked for no more than a 3/4 " raise in height. thats exactly what i got. best money spent, they do it all the time for H3,s
