Torsion lift - Pics and How To
Old 02-03-2018, 03:18 PM
blazed16's Avatar
Great thread.Was not aware this could be done on the H3. I did this on my 03 blazer but instead of raising i lowered it down.
With the Hummer i get it up. Thanks
  #92
Old 02-05-2018, 10:20 AM
ronk5865's Avatar
Default Torsion lift 06 h3
Originally Posted by JNR
Are there any worries about premature balljoint wear by doing this?
When I had my ZR2 (1999 S10 version), people would do this, but it would cause premature wear on other parts (IIRC, balljoints)...Different animals, I know, but same suspension concept...
Obviously, an alignment, as mentioned, would help, but just wondering what the long term effects, if any, are...Looks good though, levelled!
both new axles, boots are torn & had to replace a balljoint, might be a coincidence, but I can't understand why the boots would tear in less than 7 months of driving
  #93
Old 02-05-2018, 11:12 AM
blazed16's Avatar
Theres no after market or oem boots to just replace? The whole axel needs to be replace everytime correct?
  #94
Old 02-06-2018, 07:34 AM
To all new HUMMER H3/H3T owners.
If you stay at or below the recommended 23.5" measurement you should not have any issues with premature parts wear.
If you are concerned with premature parts wear, then you do not modify any of the suspension geometry.
  #95
Old 02-08-2019, 06:04 PM
Swim3395's Avatar
So when leveling out the truck by just tightening the front torsion bars what shocks would you recommend for an oem type reaction when breaking? additionally, what size shock would y'all recommend?
  #96
Old 05-01-2019, 04:14 PM
H3Luxembourg's Avatar
I changed all oems for Bilsteins 5100 series, + 2" travel, happy since years with them
  #97
Old 06-29-2019, 05:03 PM
sjbill17's Avatar
hey guys. new here. I have a question regarding cranking the T-bars. I have read a lot about it in several places and decided to just do it. My rear sits at 24 1/4" from center of wheel to fender. I cranked my T-bars to 23 1/2" from center of wheel to fender. So, yea i just leveled it, which is fine with me. I have read that 23 1/2" is ball park max on the front without too much wear on the drivetrain. However i keep reading where guys have added rear shackles to raise the rear 1 1/2 - 2 ". Now if I'm understanding correctly, that would put the rear that much higher than the front and one cannot crank the front any high without resulting in damage. Can someone please explain how guys are adding rear shackles and cranking the T-bars up enough to "level" the H3? Thanks
  #98
Old 07-01-2019, 07:38 AM
They are not "leveling" with the extended rear shackles. This would provide the same OEM forward rake and just raise the front and rear.
  #99
Old 07-01-2019, 09:28 AM
sjbill17's Avatar
Ok. So if the max available height in the front is 23 1/2 from center of wheel to fender why set the rear at 26?
whats the advantage.
  #100
Old 07-01-2019, 09:52 AM
None. Except to make the rear look higher again.
Quick Reply: Torsion lift - Pics and How To
