Front Leveling/Shocks & 35" Tire/Wheel FAQ
Old May 23, 2008 | 04:37 PM
  #21
FUM's Avatar
FUM
Default RE: Front Leveling/Shocks & 35" Tire/Wheel FAQ
Perfect !! I'm bouncin through here tryin to get all the info I can on tires, leveling, etc and this post shows up........perfect.
Now......gotta find some dirt on a roof rack with hooks.......no bars wanted.
[IMG]local://upfiles/4157/03CE6E7AF47B47F28BA01600B4F8F0CA.jpg[/IMG]
Old May 25, 2008 | 01:13 PM
  #22
mudbug's Avatar
Default RE: Front Leveling & 35" Tire FAQ
Has anyone heard how the Sandy River Enterprise 3" lift w/ rear add a leafs or w/ rear lift shackles? Are they causing any problems?
Old May 25, 2008 | 01:23 PM
  #23
rhill20's Avatar
ORIGINAL: Timgco
ANyone know the stock the height before the t bar crank? I haven;t found that listed anywhere.
I'm just going off of the 3 H3's that I have done, they seem to start out around 22 1/4 - 22 1/2". The rear of the truck is at 24", make sure that youmeasure from the center of the hub to the bottom of the fender.
ORIGINAL: kr3whum1
you said shocks instead of the kit... can you show me a website that sells the shocks?
http://www.cognitomotorsports.com/store/Hummer_H3.html
Old Nov 18, 2008 | 08:05 PM
  #24
asvinci's Avatar
Has anybody ever used or heard of the leveling torsion key lift that skyjacker makes for the H3?
Old Nov 19, 2008 | 06:48 PM
  #25
ockie's Avatar
ORIGINAL: asvinci
You don't need a key lift, all the key does is reposition your tbar starting adjustment value. The stock should give you more lift than you will ever need.
Old Nov 21, 2008 | 02:22 PM
  #26
samkelly's Avatar
Hello all.....i have put on the cognito/blistien front leveling shocks on and the ride is far better than what i was attaining from the factory shocks....if someone is looking at leveling out the front end...i would suggest putting the shocks first then doing a level from the torsion....what i found out is after you have done a torsion bar twist in increase the level of the front end and have not put on the shocks prior , you will have to to another series of torsion bar adjustments after you put the new shocks on....why?.....i havnt a clue but the i did the torsion first...leveled out the ride....noticed a decrease in shock travel then installed new shocks...my ride was cockeyed and had to re do the torsion twist as i like to call it.
the H3 FRONT LEVELING SHOCKS by Cognito are excellent....i highly recommend them but do the shocks first then the torsion bar
All the best..
SAMKELLY
Old Nov 27, 2008 | 02:20 AM
  #27
CROWNKINGH3's Avatar
The correct front Bilstein shock number if doing a Torsion lift is F4-BE5-C153-HO. The proper rear Bilstein part number is F4-B46-1698-HO for stock height rear ends. Hope this helps.
Old Nov 27, 2008 | 10:53 PM
  #28
asvinci's Avatar
I just leveled my truck with the skyjacker leveling kit and the mechanicrecomended new shocks because the oem ones were extended due to the kit. Everytime I hit a bump the truck bounces. What shock's should I buy and will they actualy help?
Old Jan 24, 2009 | 12:57 PM
  #29
Djox's Avatar
i decide to put 35" tires on my H3 but i have some doubts now on what to use !! i was gonna get Cognito Bilstein Hummer H3 Leveling Front Shocks!!! and besides that do i need anything else bump stops,lift kit,leveling kit any thing ?? I just found these they look gd quality any feedback and do i need to get leveling kit? http://www.trailduty.com/product_inf...roducts_id=778
Old Feb 11, 2009 | 07:59 AM
  #30
Ahmed's Avatar
Can we get some samples of before and after pics?
