What kind of gas..
no
it is not a worse diluted grade. the ethanol serves a purpose. todays fuel has more detergents to keepengines i jectors and other fuel systems components cleaner. case in point. rip down an old engine like say an old carbeurated 350 they used to have a ridge of carbon at the top of the cylinder you would have to ream off to pull the pistons. in newer engines you dont see this problem as much due to detergents and higher refined cleaner fuel 87 has the same amount of detergents as the 93. for a piece of mind run a can of bg44k every oil change which is awesome ****. if u cant find bg44k use lucas fuel injector cleaner. all the others are ****ty snake oil bull****
