Small coolant leak behind ac compressor 2003 hummer h2
Old 06-30-2012, 12:14 PM
taxifornia's Avatar
Question Small coolant leak behind ac compressor 2003 hummer h2
have a 2003 hummer H2 .Have a small antifreeze leak front of motor on passenger side in the area behind the AC compresor. only leaks after truck has been drivin. started very small just a few drops (now and then) 6 months ago Now is is leaking larger amounts of coolant. the waterpump looks ok also checked all the hoses they also look OK. H2 only has 40,000 miles.
ANY IDEAS>???
thanks
Old 06-30-2012, 06:24 PM
LoJac963's Avatar
freeze plug on the block maybe?? Weep hole on the water pump leaking??
Old 07-02-2012, 11:55 AM
taxifornia's Avatar
After more investigation. I found out the the 10 Ml bolts going into the bock holding on the water pump were NOT very tight. I tightened all 6 on the bolts holding the water pump on to the block and My coolant/ antifreeze leak is gone.
I am sure if i brought my hummer to a dealer or a mechanic i would have bought a 700 dollar water pump replacement. and if this has happened on my hummer it is happening on many others.
thanks GM
DOC4H
16
06-04-2014 10:10 AM
ukpaul
11-19-2011 07:26 AM
halo36
10-07-2010 01:11 PM
jacaron
06-02-2009 05:40 PM
dizzy
04-22-2008 09:34 PM
Quick Reply: Small coolant leak behind ac compressor 2003 hummer h2
